I have a column supporting a transfer girder as shown in the attached sketch. The column has a transfer girder framing into it's weak axis, however the strong axis is not framing into a slab or a beam and hangs freely, I intend to use K =2 for the column around the strong axis. Still with K=2.0, I still don't think the strong axis will control the design, since it's pretty stiff. What do you think ?
