Relative Humidity to Absolute Humidity Conversion 1
SilverGhost
New member
Aug 28, 2007
5
I have a list of data points for temperature, relative humidity, and dew point. I am looking to figure out the absolute humidity for this data. I also know the elevation that the test was run at. Does anyone know an equation that will convert this information? Or do you know of an equation that requires something not listed here, that I might be able to make an assumption about?
You can also get a psychometric chart that shows relative/absolute humidity.
JohnnyHS: Thanks for that link. It's exactly what I was looking for and it should be a great help.
willard3: The reason I didn't want to use a psychometric chart was because I have thousands of data points, all at various temperatures and relative humidities. I figured there was probably an equation that would work rather than spending hours of looking at a psych chart. Thanks anyways.
