mechengineer
- Apr 19, 2001
- 262
Normally, we use the design temperature of pressure vessel as the design temperature of the bolts of flange. However, the metal temperature of shell (directly contact to the hot medium) shall be much different with the bolt temperature by heating transfer (normally being with insualtion on the flange). Does anyone have a simple and acceptable way in engineering to obtain a relatively accurate, suitable design temperature for the bolts of dlange?
Thank you.
Thank you.
