dbachovchin
Chemical
I want to calculate pressure drop across a small (0.038 in), non-sharp-edged relatively thick (0.060 in) orifice. Flow is not choked, but Reynold number is high. There are big pipes on both sides.
Using Perry, discharge coefficient is 0.61. This corresponds to 2.7 velocity heads.
If, instead, I treat it as a sudden contraction and a sudden expansion, then I have 1.5 velocity heads, which corresponds to a discharge coefficient of 0.83.
Which is correct? Is the orifice so thick that the flow attaches? Does this result in a higher discharge coefficient? Is it generally true that if a small pipe is used as an orifice then the flow will go up for a given pressure drop?
