Dear process specialist,
I have a small horizontal vessel of about 60 liters.
It has a bottom exit pipe 1" that goes 12 meters upwards.
At this high point I want to connect a relief valve to
reduce pressure in case of external fire.
my question:
at this high point: can a relief valve discharge this liquid
from incoming (trough the upward pipe) into a existing header?
more details
vessel 60 liters
medium = methylene chloride
normal operating conditions: -25°C; 1 à 2 bara
MAWP of vessel 10 bara
relieving flow: approximately 200 kg/h needed in case of external fire @145°C (vapour pressure at 10bara of
methylene chloride
(no other case for releaving is dedected)
there is no space/room to connect a relief valve directly to
the top of the vessel wich would discharge a vapour (like an
ordinary safety valve)
I dont think the max pressure drop of 3% by API has to be
followed because I will have a vertikal going flow of liquid methylene chloride connected to a PSV ;
after this PSV the methylene chloride will probably flash from 10bara towards atmospherically pressure
I would appreciate some advice of the feasability of this
particular design.
Kkurt
my question:
more details
vessel 60 liters
methylene chloride
particular design.
Kkurt
