fdomin
Chemical
- Jan 10, 2002
- 49
I would like to understand required connection of a remote rack and a remote compressor control panels to a HC900 controller.
The rack and the control panel are for new equipment to be installed and the HC900 is existing.
Signal from the remote rack goes to a remote ethernet switch, then to a remote Fiber optic converter for a 1500 meter fiber optic run. In the control room another FO/ethernet converter and switch connects to the HC900.
Data from two different compressors must be sent to the HC900. One uses Profibus and the other uses Modbus RS-485.
As far as I know, the Profibus slave signal must be converted to Mobdus with a gateway, but then I get lost.
Should the Profibus converted signal and the Modbus RS485 be connected to the remote switch?
In the control room they must be connected to the HC900 serial port using some ethernet/serial converter after the switch?
Thanks in advance
Thanks in advance
