This must exist.
We have a heater in a remote location protected by a typical normally closed klixon bi-metal temperature switch.
Normally the Klixon would be in series with the power contactor and would shut down the heating if an over temperature was detected. But also would then take over temp control, running the system at the Klixon's temperature until it welded shut and all evidence was lost in the resulting cataclysmic fire.
I don't do 'normal'. I want the heating circuit shut down until a human has to push a button to restart it. No, I can't use a manual reset Klixon as it needs to be mounted out of normal reach and view.
What I need a box with a button on it. The heater contactor circuit needs to run to the Box. The Klixon wires need to run to the box. If the Klixon opens the heater circuit opens. The Button must be pushed to restart the heating.
Keep in mind all the usual latching circuits will not work as this system will lose all power regularly causing them to drop out and require manual resetting after every power cycle. This is not a possibility in this application.
So! Got any ideas or even a name to call this Box With Buttons?
Keith Cress
kcress -
Keith Cress
kcress -
