In a system restoration after a black-start, it is necessary that the power plant will be connected to a system substation through a transmission line of 110km.
The synchronization equipment and synchronization circuit breaker are installed in the system bus running distant 110 km away from the generator bus incoming.
How to make an automatic synchronization knowing that the TPs are distant from governor/voltage regulator?
