Removing Silkscreens from IC's 1
mgopalan
31
Was wondering if anyone knew a good solvent to remove the silkscreen on top of IC's. I have a product with 7 small PC boards but need to remove the Identifiers from certain IC's (SOIC, TQFP and a couple of LCC's) to deter certain types of individuals....
Obviously, would be nice if the solvent didnt dissolve away the IC , soldermask and the board.
MG
I have used alcohol and lotsa elbow grease in the past but definately not a good way to do it for production.
An electric eraser using the ink eraser refills. 2-3 seconds and it's gone.
Dichloromethane will almost certainly shift it. Nasty stuff - be careful.
Careful use of a Dremel drill with a polishing disk works too.
If we learn from our mistakes,
I'm getting a great education!
Have you thought about reprinting the chips with different (misleading) information ? ;-)
A star for VE1 !
I remember reading that a company copied the PC board of
an all digital instrument, ordered parts for a few thousand
and built and started to test them hoping that a large percentage will function -- but none of them worked...
A few weeks of investigation disclosed that an IC marked as
a standard TTL counter was a custom IC. This was the end of the project -- and of the company...
<nbucska@pcperipherals DOT com> subj: eng-tips
Years ago I had put together a hand-built circuit of moderate complexity. The board included several ICs that were marked with black characters on a silver background. At some point I had to clean the board with 'flux remover' and I gave it a good soaking. When I turned it over all the silver chips had been magically converted to the more-usual black appearance with white letters; and their manufacturer had changed from one company to another.
Years later I tried to reproduce the experiment with a different batch of 'silver' ICs, but the silver paint had been improved.
That's not necessarily unusual. At Fairchild, we had some p-channel parts that were completely sub'd out except for the final marking and test. I think the parts came unmarked and we put our logo and part numbers on them.
TTFN
We used some dip headers for some custom resistor networks. I found the plastic covers fit snugly over standard IC packages. I used these to hide our secret assembly - two dip bridge rectifiers installed on a 14 pin pattern. Just glued it on top of the finished circuit board. Frankly, these efforts just fool the dumbest people.
Been successfully using a dremel with the steel wire brush. I know, I know... but it works!
I saw competitors doing the same thing.
felix,
My only concern with using a steel brush would be bits of wire breaking off and shorting a circuit. I use the Dremel, but opt for a sanding disc, or even the electric erasor I mentioned above.
