plantprowler
Chemical
- Aug 10, 2013
- 136
Consider an industrial effluent which has dissolved solids as well as organics. This leads to a combined load of TDS (say, 15% dissolved solids) and COD (say, 40,000 ppm).
For concreteness, say, the solids are NaCl / Na2SO4 and the organics are innocuous and biodegradable, nothing toxic / refractory etc.
Does it make sense to remove the solids (using a multi effect evaporator) before the organics (using microbial digestion) or the other way around? Is there a certain sequence or does this depend on each facility.
