Rename CATIA V5 Product and Parts 2
ghizzo
IT
Hi to everyone.
I've a problem, i need to rename an assembly (and all sub-assembly and parts) changing only a the first part of the name.
EX :
all my files start with a code of 7 numbers, i need to change only this 7 numbers in all files
1234567_aaa.catproduct
1234567_bbb_catpart
1234567_ccc_catproduct
1234567_ddd_catpart
must become
7654321_aaa.catproduct
7654321_bbb_catpart
7654321_ccc_catproduct
7654321_ddd_catpart
There's a way (macro ??) to speed up the saving of these files ?
Thank you !
Hello SachinTata and Everyone
Thanks to forum member
I mean,
Change the name of Part & Product that start by Non-Number:
ABC****=Dce***
but this code :
ABC*** => dce***
Pleas help me for Non-Numbers in name
Best Regards
got it itsmyjob
@3DPLM
remove LCase from the replace string and use vbTextCompare as argument, then you will get the desired result
check below lines
objFIns.Name = Replace(objFIns.Name, FstStr, SndStr, , , vbTextCompare)
objFIns.PartNumber = Replace(objFIns.PartNumber, FstStr, SndStr, , , vbTextCompare)
