Rename file in Pro E
MBochnak
3
I have a part in an assembly that I would like to rename. The part name is currently xxx and would like to rename to xxx-01. It also needs to reference the drawing xxx.
Under the file menu manager, the "rename" option is grayed out.
Thanks,
Matt
The part came out from INTRALINK database? If yes, then change the following parameter in config.pro: LET_PROE_REANAME_PDM_OBJECTS YES
Procedure: Be sure you have the drawing in seesion, rename the part and save the drawing.
-Hora
To Copy Drawing Files With Object Rename in Pro/e 2001
faq554-1122
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2006 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Thanks. I'll give those methods a try.
Matt
