element230
- Jun 11, 2012
- 13
Dear all,
I’m trying to do a simplified analysis on how the integration of renewables into the transmission system would impact stability and critical clearing times.
Consider this -- Most of renewables have limited (if any) inertia and have also limited ability to respond to system disturbances and contingencies. In terms of the loss of inertia, I assume that the integration of more and more renewables (in particular wind and PV), will create a more unstable system, as these types of technologies are”behind electronics” and thus do not have a direct coupling with the system.
How I’m thinking of doing this analysis? My utility works stability modeling with PSS/e. This is a great program, but given the current state of mathematical models available for wind and PV plants, the modeling of multiple (say, tens) of these facilities is cumbersome and complicated. What I was thinking of doing was that instead of modeling these facilities by their corresponding mathematical model, I represent them as inertia-less classical generators (as I’m interested in simulate the lack or decrease in system inertia). One other way that came into my mind was to model the as negative load (corresponding to their name plate capacity), but I think this will yield in some unintended effects on the simulation.
What are your thoughts about my approach? Do you have better ideas?
As always, thank you for your comments!!!!
