Greeting Experts
our shop drilled seat lube holes on the wrong side of an valve body. Once they realized it, they welded up the 1/8” holes that go through the body into the seat pocket. The hole may have went through on one of the side plates to hub corner welds. customer inspector is stating that Section VIII does not allow plug welds
I am not sure if the welding of the drilled hole should be called a plug weld.
My question :
Is this repair define as a plug weld in ASME sec VIII ?
please reference me to related paragraph for this repair.
Thank you all in advance
My question :
