KirbyWan
Aerospace
- Apr 18, 2008
- 586
Howdy all,
I'm designing a repair for an Inconel 718 skin ~.070 thick with a crack in it. It is right next to a brazed doubler and the welder is worried about the braze metal contaminating the weld joint. He recommended using Hastelloy W weld filler metal instead of 718 to prevent any problems incase the braze metal mixes with the weld pool. I have looked around, but can not find any reference that says Hastelloy W is a valid filler wire for welding Inconel 718. Can anyone provide a reference or talk about Hastelloy W's compatability with precipitation hardenable Inconels? I'll be doing a precipitation heat treatment then an age heat treatment after welding as a stress relief.
Thanks,
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
Thanks,
-Kirby
Kirby Wilkerson
