jplay2519
- Oct 7, 2014
- 100
I have a LVL that is supporting 1st floor, bearing wall of 2nd floor and vaulted ceiling. The beam is 3-ply and was nailed together insufficiently so the outside ply is separating and the beam has also rotated making the joist hangers pull out and the joists are not properly supported. The posts are (5) 2x6 stud packs (which are insufficiently attached to each other and are separating due to buckling), the posts were not cut to the correct length so there are (2) 2x shims that the beams are resting on and are being crushed.
I am going to check the LVL to ensure it's sufficient for load, which I assume that it is, but my question is if I want them to keep the beam do you think it can rotated back into place? I want them to shore the beam, remove the posts, set the beam aright, install solid 6x6 (or whatever I calculate as sufficient) with post caps, reattach I-joists/hangers.
One photo is taken looking at the beam from directly below so that you can see the nail pulling out and the joist hanger pulling away.
