pbmechtech
- Dec 12, 2014
- 4
I am upgrading a building’s HVAC equipment with new equipment. There is currently a 5000 cfm fan coil unit supplying conditioned air to the space and a 5000 cfm exhaust fan returning the air back to the fan coil and exhausting a certain amount of air to the outdoors. The return side of the fan coil is ducted to an outdoor air inlet and the outlet side of the Exhaust fan. It is all controlled with pneumatic dampers.
My question is can I remove and replace the exhaust fan with an ERV? My space requires 400 cfm of fresh air and my bathroom exhaust requirements are about 350cfm. Can I remove the 5000 cfm exhaust fan and connect the new fan coil unit’s return air duct to the old exhaust fan’s inlet ductwork and then have the ERV to draw exhaust from the bathroom and supply 400 cfm of outside air into the return duct of the fan coil unit?
The location is Northern, Ontario with a winter outdoor design temperature of -25
Thanks in advance for your responses.
