I have the following VBA Code the lets me replace a specified string in a Part Number with a different String.
It works great, except when there are conflicting name issues.
So I incorporated Err.Number and Dictionary Feature.
Which worked great, but I would like at the end of the code to show the Msgbox with all the Parts that had errors.
The commented out section at the bottom of the code does this except it pops up multiple times because I am unable to figure out how to end the Product Counting.
If somebody could give me some pointers, it would be greatly appreciated.
Code:
Sub CatMAIN()
Set actProd = CATIA.ActiveDocument.Product
origstr = InputBox("Enter any name or number to be replaced!!! ", "Test")
Select Case True
Case StrPtr(origstr) = 0
Exit Sub
End Select
newstr = InputBox("Enter the name or the number with which they are to be replaced", "Test")
Select Case True
Case StrPtr(newstr) = 0
Exit Sub
End Select
traverse actProd, origstr, newstr
End Sub
Sub traverse(Prod, origstr, newstr)
Dim DictionaryReplacePartNumber
Set DictionaryReplacePartNumber = CreateObject("scripting.dictionary")
CATIA.RefreshDisplay = False
If Prod.Products.Count > 0 Then
For i = 1 To Prod.Products.Count
Call traverse(Prod.Products.Item(i), origstr, newstr)
On Error Resume Next
Set refp = Prod.Products.Item(i).ReferenceProduct
'Checks to See if new string has already been applied to Part Number
If InStr(refp.Name, newstr) Then
'Do Nothing
Else
If InStr(refp.Name, origstr) Then
newpname = Replace(refp.Name, origstr, newstr)
refp.Name = newpname
If Err.Number <> 0 Then
If DictionaryReplacePartNumber.exists(refp.Name) = False Then
DictionaryReplacePartNumber.Add refp.Name, aPart
MsgBox "There is already a Part/Product with the Name: " & refp.Name
Else
'Do Nothing
End If
End If
End If
End If
'Checks to See if new string has already been applied to Product Number
If InStr(refp.PartNumber, newstr) Then
'Do Nothing
Else
If InStr(refp.PartNumber, origstr) Then
newpnum = Replace(refp.PartNumber, origstr, newstr)
refp.PartNumber = newpnum
If DictionaryReplacePartNumber.exists(refp.PartNumber) = False Then
DictionaryReplacePartNumber.Add refp.PartNumber, aPart
MsgBox "There is already a Part/Product with the Name: " & refp.PartNumber
Else
'Do Nothing
End If
End If
End If
End If
Next
End If
CATIA.RefreshDisplay = True
' Call LoggedErrors(DictionaryReplacePartNumber)
End Sub
'Sub LoggedErrors(DictionaryReplacePartNumber)
'If DictionaryReplacePartNumber.Count = 1 Then
'MsgBox "There Is " & DictionaryReplacePartNumber.Count & " Detail That Was Unable " & vbCrLf & _
'"To Have Their Part Number Replaced:" & vbCrLf & vbCrLf & _
'Join(DictionaryReplacePartNumber.keys, vbCrLf)
'ElseIf DictionaryReplacePartNumber.Count > 1 Then
'MsgBox "There Are " & DictionaryReplacePartNumber.Count & " Different Details That Were Unable" & vbCrLf & _
'Else
'MsgBox "All Details Have Had Their Part Numbers Replaced."
'End If
'End Sub
