Hello All,
I have been given a task to change the process of manufacturing of a cast aluminum enclosure from investment casting to die-casting.
1) Can someone pl. suggest me a die-cast alloy with same or better mechanical properties.
2) Will the change in process be feasible without change in the design (existing design meant for investment casting)
Thank-you for your help,
bpss
bpss
