sanvik
- May 9, 2015
- 21
I want convert existing PCB design from through-hole type design to SMD design.
Is clear about selecting IC in SMD package selecting, but not fully clear about passive components: trimmer potentiometers,
Electrolytic Capacitors and resistors. There are 10 trim-pots are used to adjust frequency: 5pcs 50K trim-pots and 5pcs 5K trim-pots, and one 50K POT is used for adjust input signal level. Normally, it requires only once to adjust this. What type of SMD trim-pots can be used to replace these 50K and 5K through-hole type trim-pots? The SMD trim-pots are very small, not sure how handy is to adjust it. Also, what type of SMD capacitors and Electrolytic Capacitors can be used to replace existing ceramic and Electrolytic Capacitors?
