Reporting family table instance parameters in repeat region
swf2
4
I'm trying to include the diameter and length from family table instances in the "DESCRIPTION" column in my BOM table. For example it would read .375DIA X 2.0LNG
My parameter in the BOM table is asm.mbr.DESCRIPTION. I tried creating a relation that read:
DESCRIPTION=basic_dia "DIA X" L "LNG"
where "basic_dia" and "L" are parameters in the model and
DIA and LNG are parameters that I created. I don't know if it is a syntax problem or that it can be done at all. Any help would be appreaciated.
SWF1
Because you are dealing with strings, you need to concatenate them.
Description = basic_dia + "DIA X " + L + "LNG"
DIA and LNG do not need to parameters.
Ben Loosli
Sr IS Technologist
L-3 Communications
Bob,
Thanks for your response. When I insert that string I get an error message:
DESCRIPTION=basic_dia + "DIA X " + L + "LNG"
errorInvalid data type combination at right side of expression
If I use an ITOS function it works for the length by returning the correct value however if I use the ITOS function for the diameter it does not return a value (In the parameter list next to the parameter DESCRIPTION)
SWF2
Ben,
Sorry I meant to put Ben and NOT Bob
Steve
itos() = integer to string. Real numbers are rounded.
You might get away with something like "."+itos(dia*1000) ... and conditional statements if it gets more complicated.
Are these going to be shown in a repeat region? Seems I remember seeing (somewhere; would have to hunt for it, myself) a discussion re concatenating values in a repeat region cell, i.e. ...
&asm.mbr.dia "DIA x " &asm.mbr.len "LEN"
... Vague memory. Maybe someone else can confirm or elaborate.
Jeff,
Thanks for the info - the mcadcentral post is what I was looking for.
Steve
