Inspector67
Chemical
- Dec 16, 2022
- 2
ASME B31.3 like other codes sometimes cannot be straight forward. We are fabricating (welding) steel pipe with a PTFE liner. The steel pipe will have a tell-take hole to indicate if there is a breach in the PTFE liner. I believe this is still consider Normal Fluid service requiring 5% Radiography Examination of the steel pipe. What have you done at your job?
