swazimatt
- Aug 19, 2009
- 251
I am in the process of designing a new industrial precinct that will require a storage for firefighting and a pump to supply the network.
The idea is that the reservoir will be supplied by the network, but this will be the same network that the pump discharges into (as a booster pump and fire pump), how do i prevent the pump from short circuiting and flow just looping back into the tank
I have modelled it in EPANET and find the only way i can reduce the flow back into the tank is by restricting the tank supply diameter to 50mm. This seems very small for a 1000m3 tank with 250mm dia pipe from the pump into the network.
Is there a good source that i can read up on regarding networks with booster pumps
