slickstyles5
Aerospace
- Jun 23, 2008
- 111
I would like to determine an adequate size of a glycol reservoir that will be used in closed circuit as the cold fluid in a fuel/glycol heat exchanger. The flow rate required in the glycol line is 20 GPM. There is a quantity of 15 Gallons of fluid required to fill the pipes. Are there any rules of thumbs in terms of an adequate size for the reservoir? I heard that 3 times the flow rate is a rule of thumb. Please provide references.
Thank you,
Gabriel
Thank you,
Gabriel
