Hi all, I am looking for input on the best detail to use for a covered porch foundation. We will be using a slab on grade which will sit on a ledge in the existing concrete wall at the house side. At the outside I was originally planning to use a strip footing with block wall and over pour the slab. Is this the most economical detail or would something like a turned down slab be better? Our frost depth is 36" and there will be about 12" of reveal above grade. What is typically done in this situation? I am also concerned about the best way to anchor the posts and slab for uplift. Thanks in advance.
