I am engineering a house with a 10' tall, poured, basement walls. The soils engineer has indicated a equivalent lateral fluid pressure load of 81psf. The bearing pressure is given as 3100psf. Expansive clay has not been found...according to the soils report. It seems odd to have such a strong soil vertically (3100psf) with such a high lateral load...but I am not a geo. engineer, merely structural.
My question is simply that my math indicates vertical reinforcing of #5 bars 6" o.c. (I have assumed a pin-pin connection for the wall and the main floor as a diaphragm.) The contrator is very unhappy to say the least, as he has never done a foundation with rebar of this magnitude. I'm not asking for an exact answer, but does #5 bars, 6" on center seem reasonable or overkill from anyone else's experience?
