Looking for opinions on the residential style high velocity AC systems. Typically 2000 FPM fed through 2" and 3" flexible ducts.
Are these systems noisy compared to either the mini split VRV systems or typical low velocity hard ducted systems?
Due to high velocity, is static pressure so high as to make the fan energy significantly more than low velocity residential systems?
