Choppme
- Jul 19, 2005
- 8
Hello, I have an architect that disagrees with my detail for the exterior footing of the slab. It is detailed as a two pour slab and I have shown the 12" wide, 12" deep footing with the inside top of footing angled at 45 degrees toward the exterior edge instead of the typical 45 degrees toward the interior of the slab.
I was told that as long as the cold joint at the top meets the minimum stemwall width (6"), that inside corner area in question could be angled either way.
Any help would be appreciated, thank you.
