bigwaterbill
Materials
Will reducing water pressure from 80 psi eliminate water hammer? What pressure would be needed? Any and all suggestions appreciated.
1/2 copper cold water supply line coming off 3/4 main line. Feeds 9 cold water fixtures and all cause water hammer at the tank-less water heater. All fixtures are within 12 feet from each other. Longest line is 14 feet.
Flow rate at the end of this line at hose bibb is 7.46 gpm. There is no PRV, expansion tank, check valve is the system. City water system with 5/8 water meter without back flow valve.
