peelwvu
Geotechnical
- May 20, 2014
- 14
Working on a fairly simple sheet pile design which is nice because it's my first one. It's for DOT and LRFD is required. I'm using Shoring Suite Software. I started out using Strength Case Load Factors for all of the loading. 1.5 for Earth Pressure. 0.75 for Passive Pressure, 1.75 for Live Load.
It's only and 8 ft. exposed height and water is assumed at the top of the wall as per the spec. I'm getting embedment lengths of 31 ft., which seems like a lot. I read in the manual that the program automatically adds 20% to the embedment length and that AASHTO requires 30%.
Should I be using service load factors, since a factor of safety is already being added by the program?
