Resolution Precision Accuracy of a ruler
Hiviz
28
Hi
For testing purposes I have to measure the change of a distance (about 50mm). Easy. I would like to use a steel ruler instead of a dial gauge with rod for it, but the standard I am working to says that the instrument should have a resolution of 0.5mm and a precision of 0.1mm. I can get a ruler with 0.5mm increments, but I am struggeling to tell what the precision of my instrument (the ruler) is. And then there is accuracy, but I guess I have that sorted if I have the ruler calibrated...
I understand what precision from the definition point of view (Precision is how close the measured values are to each other)but am unable to apply this to my ruler problem. How can an instrument have a precision of 0.1mm when the resolution is 0.5mm?
Hope somebody understands my problem...
I understand if precision in the standard would read accuracy I am ok with my steel ruler (as long as it has got the right accuracy. Will contact the standard people to clarify.
And yes, I consider using stops for better readability.
