A few more thoughts, mostly just repeating stuff already mentioned above (before I block this site for the rest of the day!):
[ol 1]
[li]Even if we all agree that a 1.02 code check is unlikely to result in an issue, why invite the potential scrutiny? The general public will perceive it as black and white. You're taking on risk for no good reason. Per the example above, you really want to risk being at 0.0816 when you could have easily been at 0.0799? The two are not the same. While you might be able to argue that 0.0816 is ok because you "doubt if machines can measure that accurately," if nothing else, you now have to prove that![/li]
[li]I'm currently going through the slightly painful process of getting insurance, working on a solid engineering contract, etc. The term that keeps coming up is standard of care, which basically means providing engineering services that are roughly equivalent to competent engineers performing similar work in a similar location. I would be concerned that showing a beam calc. which indicates a 2% overstress might not meet the standard of care. I could be wrong though. It could meet it if others in your area have a similar practice. I would certainly be cautious though. Now, would an insurance company deny a claim for this reason? I would hope not, but I wouldn't put it past some of the slimier ones.[/li]
[li]Finally, I think if this thread had been about you being blamed for a structural failure/problem and it was discovered that some of your calculations indicated a small overstress, I think we would likely all jump to your defense, saying that the problem couldn't have possibly been due to that or due to that alone. I see what you're doing as a risk with no reward, and my intention is only to try to help a fellow engineer out, considering that you don't see it this way, which to me is surprising.[/li]
[/ol]
