CHARLESCOSTA
- Aug 26, 2007
- 27
A lifting tackle beam is to be designed which has 4 circular holes in the web(centers coinciding with mid point of web height)symmetrically placed with respect to mid point of beam length.Two holes will be used to suspend load through hangers connected to pins passing through the holes and two holes will be used to lift the tackle with crane hook holding pins passing through the holes.At the vertical section passing through center of holes,i weld bearing bosses(pins will bear on these)and use stiffeners welded above and below these bosses to the web such that moment of inertia and area at these sections become equal to those at sections not having holes.Is this method good for practical purposes.I am aware ofNCCI design rules for web opening in beams ,but i haven't used it.The above method which i have read in some old book seems easy to me,since in any case i am going to use bearing bosses to reduce bearing stresses on pin.
