Hi
I am doing a structural analysis.
How we can define model & loads in a coordinate system and have the results(such as stresses ,etc)in the other defined coordinate system(a global CS for whole of the model generated by rotated axis, using "CLOCAL").(however we can calculate it out of ANSYS ,by using related matrix for rotated axes).
I try it by two ways:
1-using "csys,kcn" after /solu and just before SOLVE command
2-and also after /post1
But it did not work; whole of the model (geometry & load) rotate & so the results will be the same!?
May I have your advice?
