resume help
mbdoc3
1
I just received word that I passed the FE exam and am wondering how one would suggest wording that on my resume. Had someone suggest to add an addition title of "Licensure" and insert it under that, but I'm questioning the actually wording.
Thanks in advance for any help!
"Licensure" would be misleading - bad if you're looking for a job. I suggest "Engineer-In-Training", or "EIT" somewhere in the resume, perhaps under the "organizations, honors, awards" area.
Or, "passed Fundamental Engineering exam"? I don't suggest you give 'em your score, though.
First, congrats on passing the FE test.
Second, I have to agree with ICman. An EIT is not really licensed; though you can definitely include 'EIT' as he suggested. Take the PE test as soon as you can(with the proper study).
mbdoc3,
How about "Successfully passed Fundamentals of Engineering (FE) Exam towards earning Professional Engineering License"?
Best regards,
Matthew Ian Loew
You might want to call yourself
"mbdoc3, E.I.T."
in the name block of you resume. Immediately that tells the reviewer that you successfully passed the EIT. Congrats!
All good comments above.
Some US states (most, I think) are changing the EIT designation to Engineer Intern (EI).
You might want to check out your local area's practice (or the areas where you are seeking employment) to get the proper title.....just semantics, though.
In the UK there is a tendency to put academic and professional qualifications seperately.
You could have a section 'Professional Qualifications' or 'Professional Standing' and under it put your progress so far and a statement like 'can demonstrate successful progress to professional engineer status'.
No more things should be presumed to exist than are absolutely necessary - William of Occam
