1
- #1
phamENG
- Feb 6, 2015
- 7,677
One of the municipalities near me has instituted a new retaining wall ordinance. When a retaining wall is being built, the engineer of record now has to provide life cycle estimates and a maintenance plan. (The owner then has to file a restrictive covenant on the deed agreeing to abide by the maintenance plan.)
This is a new one for me. Anyone have any suggestions? The wall I'm working on is cast in place concrete. Here's what I'm thinking for the maintenance plan:
Upon Completion of Construction:
Survey to fix location of top of wall and bottom of wall (horizontally and laterally) at points not to exceed 20' along the length of the wall.
Every year:
-Clean the wall of any algae or moss growth
-Visual inspection of the wall to ensure no cracking, weeping of water through joints, or noticeable movement of the wall is occuring.
-Inspect drainage to make sure it isn't clogged. (I'm considering requiring a clean out at the high end of the drain to allow a snake to be run through it- thoughts?)
Every five years:
-Survey the wall to check movement of wall against post construction benchmarks. If 3 consecutive surveys show less than 1/2" of movement over the 10 year period, discontinue surveys. If surveys show movement of greater than H/100, then the wall should be checked more often.
As for life cycle...I know it could last 100 years if built well and maintained...but I feel hesitant to put more than 50 years on it. Anyone have any good data sources for infrastructure lifecycle estimates?
Thanks.
Every year:
Every five years:
Thanks.
