sybie99
- Sep 18, 2009
- 150
Question: I designed a concrete retaining wall, the base is 500mm thick. Now my design usually allows for a safety factor of 1.5 against slip/sliding. In this design a very small force is used as passive pressure onto the front toe of the 500 thick wall base.
If the base is excavated into virgin ground, (dense solid gravelly material), for the base to slide this 500 thick base must push through this material. So in reality the reactive force on the toe of the wall from the in situ soil material is much higher than the passive force used in the sliding calculation, as long as it is okay for the wall to move slightly so that this soil can compress provide a reaction force.
Sure there might be some movement as the toe pushes into the soil but as it then compresses how will the wall slide, it must shear through this material, am I right?
Has anyone ever seen or heard of a retaining wall slide before actually overturning or failing in bending of wall?
Just seems to me that in the described case the calc for sliding is too conservative in most cases.
