retaining walls design program
Guest
i am looking for a program or an excel worksheet for the design of retaining walls
does anybody have one?
thanks
Check with American Concrete Institute (ACI), they have some inexpensive ones with good documentation. However, if you build one yourself in Excel, you would understand the process much better.
If you have used Mathcad it can be very useful. Once the calculation is set up it would only require changes in the variables in the future. It also shows all of your work and can easily be checked.
While I am an advocate of MathCad I must say that a retaining wall complex or simple may be handled via spreadsheet quite quickly. I recommend a spreadsheet and a good text on foundation engineering...something like Braja Das or Bowles.
Use RetainPro from Enercalc or STAAD.etc from REI...both are good.
