Retrofit foam adhesive masonry veneer ties
shobroco
281
I read an earlier thread in which Ron stated that he has used expanding foam adhesive to tie masonry veneer to its back-up when the original ties had failed. I have never heard of this before and had the same initial reaction as hokie66, but I am interested in learning more. I frequently deal with heritage masonry buildings that require remediation of the ties between inner & outer wythes & we usually use drilled-in helical anchors. Stone walls with failed inner cores are usually grouted, but the possibility of using foam in them offers the added benefit of insulation. I am looking at an 1830s building with this problem right now. Has anyone ever done this?
The mortar comment was cautionary, not intended to be condescending... see too many 'screw-ups' with mortar and too many from improper repairs.
Is the inside of the wall plumb? or, does it exhibit a similar curvature? Interesting that a 24" wall at the corner of a building has a curvature.
Dik
In Canada, eh... any chance of water penetration and freezing issues?
Dik
The inside of the wall is reasonably plumb. I'm sure there have been frost issues over the years, & of course it only accelerates once water starts penetrating. Preventing that is part of the project.
