Return value of cell next to empty cell
jkate
66
I need some help with VBA code to look at a two column array (columns A&B) called POLog, find the last empty cell in cell Bx (with "x" being the row) and return the value that's in cell Ax. I then want the value from Ax to be placed in a cell called "PONumber". Can someone help me with that?
Thanks.
Range.Rows.Count - Range.Row gives you the row number of the last row of the range.
Loop backwards through rows in column B until you find an "empty".
Get the value from the corresponding cell in column A and set that as the value of "PONumber"
Assuming a Range Name of PONumber...
Code:
   [PONumber].Value = [B1].End(xlDown).Offset(1, -1).Value
Skip,
[glasses]Just traded in my OLD subtlety...
for a NUance![tongue]
Thanks.
What if the two column array is on another worksheet in the workbook?
Code:
   [PONumber].Value = Worksheets("Your sheet name").[B1].End(xlDown).Offset(1, -1).Value
Skip,
This seems to work, but I get an error. It doesn't like .Rows
Sub PONumber()
Dim lastRow As Long
Worksheets(POLog).Activate
lastRow = Cells(.Rows.Count, "B").End(xlUp).Row
End With
Range("PONumber2").Value = lastRow + 1
PONo = Range("A" & lastRow + 1).Value
Range("PONo").Value = PONo
End Sub
JKate, I'm surprised your macro got past its orphaned "End With".
It didn't. I didn't have the most recent code in my last post.
Below is the current code, but I still get an error. It doesn't like .Rows. When I run the macro, .Rows comes back highlighted in blue.
Sub PONumber()
Dim lastRow As Long
Worksheets("POLog").Activate
lastRow = .Cells(.Rows.Count, "b").End(xlUp).Row
Range("PONumber2") = Range("A" & lastRow + 1).Value
End Sub
Code:
Sub PONumber()
   Dim lastRow As Long
   With Worksheets(POLog)
       lastRow = .Cells(.Rows.Count, "B").End(xlUp).Row
   End With
   Range("PONo").Value = Cells(lastrow + 1, "A").Value
End Sub
Skip,
You ought not use Activate & Select indiscriminately. It is very inefficient.
Skip,
Ok. Thanks for your help. Everything seems to work except for 1 thing. The code is note placing the value of Range("A" & lastRow + 1).Value into cell PONo on worksheet POLog. Below is the code. The code is more than I've posted before because it needs to preform other functions like clearing the PO Form.
Sub DisplayForm()
Dim lastRow As Long
With Worksheets("POLog")
End With
Range("PONo") = Range("A" & lastRow + 1).Value
Range("POnumber").Value = ""
Range("SubTotal").Value = 0
NextItem = Range("NextItem").Value
PORowStart = 13
Range("B" & PORowStart + 1, "M" & PORowStart + 1).ClearContents
If NextItem > 2 Then
For i = (PORowStart + (NextItem - 1)) To (PORowStart + 2) Step -1
Rows(i).EntireRow.Delete
Next i
End If
Range("A1").Value = 1
ProductSelection.Show
Range("POnumber").Value = Range("PONumber2").Value
End Sub
Code:
 Range("PONo") = [highlight #FCE94F]Worksheets("POLog").[/highlight]Range("A" & lastRow + 1).Value
Skip,
That did it Skip! Thanks so much!
I'd also disambiguate ALL the sheet references.
Code:
Sub DisplayForm()
    Dim lastRow As Long, NextItem, PORowStart, i
    Dim wsSUM As Worksheet
    Set wsSUM = ActiveSheet     '[b]I would prefer a specific sheet name here[/b]
    PORowStart = 13             '[b]this ought to be derived[/b]
        wsSUM.Range("PONumber2").Value = lastRow + 1
        wsSUM.Range("PONo") = .Range("A" & lastRow + 1).Value
        wsSUM.Range("POnumber").Value = ""
        wsSUM.Range("SubTotal").Value = 0
        NextItem = wsSUM.Range("NextItem").Value
        .Range(.Range("B" & PORowStart + 1), .Range("M" & PORowStart + 1)).ClearContents
            .Rows(i).EntireRow.Delete
        Next i
        End If
        Range("A1").Value = 1       '[b]Which sheet???[/b]
    '    ProductSelection.Show
        wsSUM.Range("POnumber").Value = wsSUM.Range("PONumber2").Value
    End With
End Sub
Skip,
