  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Reuse Library, pictures on folders.
SteffenJoergensen
9
Hi all.
We´ve been using Resuse library for some time now, and we´ve started to get a lot of files into the different folders.
When i open these folders im able to set the view to Thumbnail, Preview etc. so that i am able to see the pictures i´ve attached to the object.
Thats very nice, but im getting request concerning the folder structure. My employes would like to be able to navigate easier inside Reuse library, if the folders had telling picture attached to it. I´ve attached a picture of a folder , were the picture could be ejector pins..
Sure, its easy enough to read it, but none the less im getting this request, and i haven´t been able to fix it on my own
Steffen
LEGO denmark
RMB on the folder and you can change the folder icon.
Remember that you need to have the picture.
Thank you...
Using NX 8 and TC9.1
Hi Cubalibre00
If I understtand you correctly, I am suppose to Right mouse button on the folder in member select?
I´ve tried it many times, which also was the reason I wrote this thread. It wasent working in 7.5, so i installed 8.5, but this dident work either?!
The only option i get when i RMB on the folder is, OPEN
Steffen
