Rev table
ctopher
17,456
Has anyone come up with a way to change the Rev Table to show the date as 09-07-04? This is the standard our corp wants us to use. The default of the table is 9/7/2004. I have searched everywhere and have not found a solution.
thanks
The date is controled by windows. You would need to set up windows to display the short date.
Open Control Pannel. Reginal Setting. Click on the date tab
Change the Short date to MM/dd/yy
That should change your setting to what you want. Keep in mind that all your dates now will be displayed that way though.
That's what I was looking for. Thank you!
