Reverse 240V Motor 2
KeithCarrier
9
I have a 240V single phase capacitor driven 1HP motor.
How do you reverse the spinning of the motor?
Thanks very much Bill, never thought of that. I will have a poke around in the morning to try and find the centrifugal switch
Cheers
David
Your welcome oldtinkerer. If you can get a picture, don't overlook Scotty's offer. He may be able to save you some time.
Bill
"Why not the best?"
Jimmy Carter
Thanks Scotty, think I fouled up my reply so here goes again. Attached (hopefully) photo shows the panel with mains input and capacitor removed for clarity. Mains input was between AZ ans A and the capacitor was between A ans Z (Z is the lower right hand terminal with the yellow wire attached- the Z is obscured in the photo !
 http://files.engineering.com/getfile.aspx?folder=bdac322a-3cf0-420d-8c6c-43e35263ed46&file=P1010096.JPG
I've had a look for your motor's connections and I have one which is close but not an exact match. It's close enough to work out what's going on, but the way the centrifugal switch is implemented muddies the water a little.
The winding colours in your motor appear to be consistent with Brooks standard wiring code:
Run winding - red and black pair.
Start winding - yellow and blue pair.
The brass strip from AZ is likely one end of the connection to the centrifugal switch, and the other side of the switch returns on terminal S.
I've enlarged the Brooks diagram and marked up how I think your motor is internally connected. If you have a multimeter, you should find you have continuity between AZ and S when at rest. If you haven't then the switch might be sick - not an uncommon fault by any means, and not hard to fix. Be gentle when dismantling the motor!
Reversing is as per the diagram - swap the yellow & blue cores.
Hope this helps.
image.php
Geronimo ! Worked a treat ! Checked out connections with multimeter and they fitted your circuit so I reversed the yellow and blue and off she went in reverse. Just a moments worry as a horrble rattling noise started, but that turned out to be a loose pulley on the drive shaft. Very many thanks Scotty and you too Bill your help has been really appreciated.
David
Hi Guys,
I am new in this forum. Although, I've been reading various posts from this forum for quite some time now and I give kudos to everyone that has contributed immensely for a job welldone.
Thanks.
Victor(Micristos)
Hello Victor,
Welcome to the forum. I'm glad you find it useful and interesting. Speaking personally, it is little notes of thanks like yours and that from David above which make it all worthwhile. So thank you for your kind words.
image.php
What Scotty said.
Bill
Bill
"Why not the best?"
Jimmy Carter
That was a good thread.
Slightly off topic but some motors such as small shaded pole without means of swapping the start winding can be reversed by taking off the end bells and swapping them around i.e. poking the shaft out the opposite end of the windings.
Roy
Hello all,
Sorry for the latency in my post, but here's my 2¢ anyway! ;)
I have many Motor Connection Drawings posted on-line at ECN, which may be of assistance to Members needing references.
In particular per this Topic, check out this page:
This Page has Schematics of basic Forward / Reverse connections for Split Phase resistance Start Squirrel-Cage Induction Motors.
To view all the Drawing Page Links available, check out the Main Page:
Good luck to the OP!
Scott
BTW, I have attached an Image of a Single-Voltage 1 Phase S.C. Induction Motor connected for Clock-Wise ("Reversed") Rotation.
Eye Arrrgg an Injunear :)
