It's been a long while since I designed equipment utilizing a reverse flange. We use Compress for our design calculations, and I was surprised by the specified weld size they came up with. I brought this up with Compress and they referenced a code paragraph that I'm not sure applies. I'd love to hear your perspectives.
We are using a loose ring type reverse flange per Fig 2-13.2 - with an attached shell thickness of 3mm.
Per Appendix 2 paragraph 2-13(a)(2):
Per Figure UW-13.2 sketch (d), the required weld sizing is: a+b shall not be less than 2ts. In addition 'a' shall not be less than ts, and there is a limit on the setback from the the outside face of the reverse flange. If the reverse flange diameter is equal to the shell OD, then a=ts, so the requirement becomes b shall not be less than ts. In our case with a shell thickness of 3mm, this would mean 'b' shall not be less than 3mm.
Compress however is resulting in a required weld size 'b' of 6mm. After contacting their customer support, they referenced paragraph UW-13(e)(2) which states:
So here's my question... paragraph UW-13(e)(2) specifically mentions Figure UW-13.2, sketches (m) and , does it also apply to Figure UW-13.2, sketch (d), when it used for the attachment of a reverse flange?
(I know the sketches in the code are never to scale in any which-way, but as a point of interest I measured the weld size in Figure 2-13.2 relative to the drawn shell thickness. That figure would suggest that weld size 'b' from Fig 13.2, sketch (d), would equal ts...).
Thank you!
Marty
The shell-to-flange attachment of loose ring type reverse flanges may be attached as shown in Figure 2-4, sketches (3a), (4a), (8), (9), (10), and (11) as well as Figure UW-13.2, sketches (c) and (d). When Figure UW-13.2, sketches (c) and (d) are used, the maximum wall thickness of the shell shall not exceed 3/8in. (10mm), and the maximum design metal temperature shall not exceed 650°F (340°C).
(2)For flange rings of bolted flanged connections, as shown in Figure UW-13.2, sketches (m) and , the sum of a and b shall be not less than three times the nominal wall thickness of the abutting pressure part.
Thank you!
Marty
