PPN_LCP
Marine/Ocean
- Jul 13, 2021
- 3
Hi All,
I'm currently in a project where a client chooses to decommission pipeline by reverse s-lay method.
I personally have exp in conventional rigid pipelay using s-lay method where a lay barge equipped with tensioner(s) and stinger is utilized.
Nothing fancy for start up/normal lay/laydown operation.
Normally during pipelay, the pipeline needs to be applied tension to ensure sound structural integrity of the suspended s-shape section. This too applies when we do reverse s-lay. Given that both ends of the pipeline are cut(normally by diamond wire), when we recover the first pipe end, there is not much an issue. We can use PRT (Pipe Recovery Tool or equivalent) to insert into the pipe cut end. The PRT is connected to A&R winch on the barge for providing tension as required. However when we approach the other end, I still question of how to apply tension to the suspended recovered pipeline since the pipeline end is already cut thus there is no mean of restraint.
Another thing that I can think of is to stop the barge at X distance (approx 1000+ metre) to the pipeline end. This is to ensure we have enough friction between the section of pipeline on seabed against the tension that we need to apply. The remaining "X" length of the pipeline are to be recovered by Cut and Lift method.
Anybody who have done reverse s-lay before please feel free in shim in and advise. All recommendations are welcome.
Thank you.
Thank you.
