Comcokid
- May 23, 2003
- 1,277
I am working with a product problem. This industrial product was designed around 1970, and consist of a mixture of discrete transistors, and LM741/LM308 opamps. In other words, the engineers who designed it are long gone, and the circuit approach is not-at-all what would be done today. But I need to fix it with minimum changes.
Through shear accident, it was discovered that the problems with the design could be fixed by reversing the collector and emitter on a 2N3906 PNP. This transistor is part of a multivibrator circuit (NPN and PNP in a SCR-like arrangement) being fed from a 11 ma constant current source and capacitor through a double emitter transistor (to create a ramp). Reversing this transistor keeps other opamps off the rail and solves temperature drift problems of the circuit as a whole.
Here is the issue. I can find little data on using a PNP transistor with collector and emitter reversed, just a Wikipedia reference about how the gain is much, much lower. Since the transistor is driven by a current source it is protected. What other information can anyone tell be about using a PNP transistor with the collector and emitter reversed? What other characteristics do transistors have when used this way?
