Revisions
Mechomatic
50
Hello All!
My company uses Solidworks 2012 for all of our 3D CAD and production drawings. We have a standard product line (which is modeled up in the appropriate file location) that we then customize for customers. Each customre gets a job folder where we save a copy of the basic equipment configuration, then make any changes as needed for the specific job. The issue I'm trying to find a solution to is when we make revisions to drawings and/or models. We're constantly having to go back to recreate drawings because links get broken, or what have you. Can anybody share their "best practice" for making revisions to drawings/subassemblies to retain the old information (don't want to break any drawings from previous jobs on accident) but not have to spend quite as much time redoing drawings when a revision is made?
Thanks!
How are you copying the original product files?
You should be using the SolidWorks Pack and Go tool to copy all files (including drawings) which should preserve all links & references.
How many users? The Search engine on these forums is very robust. If you're not using PDM, you'll have to get creative.
thread559-61350
thread559-43193
thread559-249325
thread559-4904
thread559-308851
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
We don't track revisions in our models or drawing files. But we do create a PDF of every drawing revision. It's not a perfect system, but it doesn't break references... and if we have a good PDF drawing of prior revisions, we can always re-create a prior revision if needed. So, to clarify... our models and drawings are always the current revision. This being said, in the near future we will implement a PDM system. Then we will be awesome..!
Also... PACK AND GO is a powerful tool... study up on it.
And... You can change the REFERENCES of a drawing.
Search for "Edit Referenced File Locations Dialog Box" in your help menu.
Jack L Tate - Xtreme Tower Products - SolidWorks 2013 - Windows 7 - Microsoft Wireless Mouse 5000 - SpaceNavigator - Slacker Radio - Swingline Stapler - [COLOR=red yellow]C8H10N4O2[/color] - Rental Bowling Shoes - Titanuim Spork - And that's all I need!
It's common for some CAD users to to do a save as for drawings into their own folders, leaving the models broken in other paths.
I see this all the time.
Good suggestions from others here. I use PDMWorks to track all files.
Chris
SolidWorks 13
ctopher's home
SolidWorks Legion
we have a folder where we place a pdf of the part BEFORE the new rev. We never change the name of the original file drawing or model. This is if the new rev is a minor change and will be used in all new assys. If the part has a major change, we just give it a new PN. If you are using different revs of parts, that it where things get confusing. I think our company is going to go with Enterprise or some other PDM shortly. good luck
