MOHAMMED89
For an API 650 tank, with dimension 12(D)m x 20(H)m. Bottom shell course of A36 with 10mm thickness.
Tank is provided with anchor chair and also RF pad considered for this anchor chair. and there are two nozzle N1 & N3 (let say inlet as N1 and Outlet as N2).
My concern is that the clearance between the nozzle RF pad and anchor chair RF pad is only 75 mm. When i check in API 650, as per clause 5.8.1 the requirement is mentioned for shell material for group IV and higher. and i haven't find any clause for weld clearance for shell material I, II, III and IV.
Kindly advise with clause i have to follow for weld clearance.
