Agrezar
- Feb 17, 2012
- 12
Im trying to match the RGB values for a customer's color coding for machineing tools. I’ve exported a parasolid from KeyCreator with the proper material color set for multiple sheets labeled, imported into UG and matched the closest color, then manually changed the RGB value of that color to be the appropriate RGB value. It looks good in UG, but when exporting step and importing step into KC the color goes back to their original RGB values before editing that color in UG. Maybe my approach is wrong. Any ideas how to do this properly? This may seem trivial to some, but i work for many tool shops and id like to nail it down.
