Apr 8, 2010 #1 gigon Mechanical Feb 17, 2010 18 0 0 CZ Hello, I want to create a drawing from a part with some ribs. I have a section and I don't want to cut the ribs. Is this possible? Thanks
Apr 8, 2010 #2 kthant Mechanical Jun 28, 2007 44 0 0 CA hello Make cutting lines for plane with 90 deg to avoid ribs or right click on a drawing view and " set drawing view depth " Hope something is usefull Upvote 0 Downvote
Apr 8, 2010 #3 beachcomber Mechanical Jan 19, 2005 1,488 0 0 GB Not automatically, and I don't think any CAD system will. You can do it by removing the hatching from the view, adding a line by drawing in view and then manually hatching. Other than that most people just live with it being not to standards. bc. 2.4GHz Core2 Quad, 4GB RAM, Quadro FX4600. Where would we be without sat-nav? Upvote 0 Downvote
Apr 8, 2010 #4 KENAT Mechanical Jun 12, 2006 18,387 0 0 US Actually, some of the newer versions of the standards do allow ribs to be sectioned as I understand it, presumably a concession to CAD. Posting guidelines faq731-376 http://eng-tips.com/market.cfm? (probably not aimed specifically at you) What is Engineering anyway: faq1088-1484 Upvote 0 Downvote
